- Joined
- Dec 28, 2006
- Messages
- 377
- Points
- 118
HI guys, hoping you guys can help. My alfa guilietta 2.0 jtdm had a broken wire on the start stop sensor (gearstick bit). I had it replaced but when it comes to calibrating it on multiscan ecu its say complete and nothing has changed. And still say neutral position sensor. I have had it in at a auto electrician to fully check all the wiring and everything is fine. When plugged into the diagnostics it shows the gears changing etc when you move the stick but it will not set the neutral position. Does anyone have any ideas? The check engine light is on because of this and i have run out of ideas on how to clear the fault.
