Withnail80
- Joined
- Dec 9, 2019
- Messages
- 1
- Points
- 1
Hi, I just brought a Panda 100hp to use for driving around the city, but I have a few questions as it needs a bit of work.
Gear Stick: It’s got a bit of play in it and the reverse lifter doesn’t spring back down. So some advice on the linkages or bushes to make it tight and how to sort out the reverse lever to spring back down.
Steering Wheel Peel: I know this is a common fault, was looking at a Abarth 595 wheel, but it doesn’t come with the Airbag. Firstly, I am assuming it fits even though it’s a newer model, yes or no... and if it does fit, where can I get just the airbag from or is the one out of mine interchangeable? Or should I wait till I find one with an airbag and not mess around?
2 other things; there’s a noise! It’s like a rattling sort of noise. It only happens when the car is in motion, sort of sounds like it’s coming through the footwell.
Depressing the clutch or higher revs don’t seem to affect it.... i know it could be about 20 things, buts it’s strange and doesn’t sound like the groan of a bearing ??*
.... also had the Red steering wheel, but don’t need answers on that until I’ve put it on a scanner and can give more information. It only popped up once and went away and hasn’t come back.
Many thanks in advance... apart from those things it’s a fun little car
