The charity i help out have a 03 plate 1.9 D. It ran for 15 mins and cut out but would restart. We had to change the pump in the tank as it had failed. Also possibly Relay 10 that is i series with the pump was suspect as well, so that's been changed. i jumped the pump to bleed the fuel system. We ran the van for an hour van and the relay gets quite hot. The fuses are intact so the current draw and no shorts but you can't hear the pump running. Anyone know what the relay does? and cannot understand what it switches in the ECU terminal 81. I'm just a bit worried that may have problems in the future. Any advice appreciated from grollie.
