Front Subframe..!
Front Subframe..!
J
John
The wife's Bravo has failed the M.O.T. Rust holes on the subframe close to the wishbone mount.
Looks like a reasonably straight forward job, question is :- Is the subframe bolted and bonded to the floorpan? Has anyone done this job. Any input would be appreciated.
Cheers,
John.
ooo...i had this with mine, but luckely i spotted it before the MOT
its a hell of a job lots of bolts.
2 big bolts holding it in each side at the front, then 4 or 6 more at the back then the rear gearbox mount also bolts to it and so does the steering rack. can be done in a day.
its not welded on anywhere so its a straight forward job i did it by myself so it not that much hassle its just time consuming
She's a monster soon to be revealed :)
If they didnt want it stripping they shouldnt have used nuts and bolts :)
they are just bolted one its a 3-4 hour job with someone helping you working on the floor. on a two poster lift you can do it in about 1-2hours
M
2
741
M
383
dan brush
N
229
Nuno Costa
N
C
2
253
colin
C
