Fiat Multijet 1.9 8v 120 BHP
While being driven intermittent ABS EBD errors occasionally "switch off Engine" once fuel gage dived to empty and I had a message telling me to refuel I had 1/4 of a tank left!
After about 20 min it slowly returned to normal.
Abs seems to be working fine even when I'm being told its not working.
Took it to a garage today and looked at the error codes we had the following:-
Central ECU Delphi Marinelli
Fault Memory 9006 Fuel level sensor Signal above maximum threshold
D0602 C-Can bus line error Signal not valid / intermittent
Anti-Lock braking system - Teves Mk20/70
Fault memory 31 ABS indicator lamp.
The lamp works (too well) any suggestions folks?
