Technical stop light not working
sergey shalit
hey
the stop light in my fiat bravo not working
not left not right and not the middle
what can be the problem?
it can be fuse?
fuse or switch depress the brake pedal with something and check for a supply voltage at the back, if you have 12v then check the bulbs, if you don't have any voltage check the fuse then the switch
