Technical  When I start the Cinq, smoke comes out.
Malta
When I start the Cinq, smoke comes out. The colour of the smoke is like greyish whiteish. Cannot really tell the colour. The smell is like of oil and some petrol of the same time. The car has oil. This happens when I start it in the morning and when its cool. The temperature still rises till next bar above 90 and the fan kicks in, not for long. The system is bled. The water pump has been changed and even the coolant. Gave it 50/50 Paraful ready mixed. What is the problem now?
Thanks for the help.
No, no fluids are being lost. I see nothing on the floor in the morning. But the fuel comsuption has increased. 192M with 32Litres of petrol. Where is the breather? One thing I forgot to mention is that I have two noises. One is a scream, it increased when I rev the car and the other one is a rattle noise done when its idle until 1300 rpm. These noises are coming from where the timing belt is.
I'd remove the air filter, housing, same reason '99 is addressing.
Symptom is typical of Citroen 2cv when parked on camber, oil seeps through rings - smoke on starting.
Stop what?
If the breather is blocked, soak it overnight in petrol (etc.) wash it out and re-attach.
If it's fuming, do dry and wet compression test (to see whether the valves or bore wear are responsible).
For the rattle, check the valve clearances and re-shim as appropriate.
For the screech, replace alternator or bearings or replace timing belt and tensioner (depending on what makes the noise).
The breather may clog because of the duty cycle of the engine, my roadster needs the breather cleaned every 10k miles other wise it uses a lot of oil been doing it for 80k miles.
Cruising for several hours at indicated 75mph.
Noel
The breather is fine and clean. I change the temp sensor about 1 month ago. Nothing happened when I changed it. Do not know why it is doing this. People are telling me that its the head gasket and cylinder head... :mad:
If the head gasket has gone then you will be losing water, which you aren't, unless its gone between cylinders, but that would only give a lumpy idle with no loss of fluids.
Which temp sensor did you change?
SPD
The 2CV does a lot of white smoke on start up on very little oil consumption, dont think one should park it on camber, aircraft radial engines need to be reverse rotated twice to avoid damage, from oil in cylinders on start up.
Noel
I changed the blue temperature sensor which is going in the inlet manifold. I changed it because the injector light was coming when it snapped for me when I was cleaning the engine... Very fragile! I see no fluids on the floor and neither droplets of any kind of fluid. The car does consume oil. I mean after 2000 miles I have to top it up again. I think that it is the head gasket as its overheating and doing this white smoke, but what I noticed now is that, two days ago I was late and I had a date and so I reved the engine and was doing high speeds. Did not know that this Cinq does more then 140 KM/hr. I was impressed. Now the white smoke stopped coming out when I start it but it still overheats and the fan stays on for 5 seconds. The colour of my fan switch is black while of my friends its blue and it stays on for 2 minutes min. My friends temperature needle stays a bit below the 90 even when in traffic and when leaving the car for 30 minutes on idle. The highest temperature which the car reaches is the next bar above the 90. This car is driving me insane!
