Technical Punto JTD engine replacement
Jasperado
Donate Donate Donate!!!!!
Scotlandshire
Looks like my head has been skimmed before leaving me with interference between valve and piston which is making my jtd run like a tractor. Thickest head gasket being used already! Can you just bolt in a different engine or do you have to replace the ecu etc?
If it's the same spec I don't see why not.
Why don't you just replace the head?
I doubt this is the actual problem.
As per the puntomk2 forum, check compression to test if you have a broken valve, I think however it just needs some treatments through it if its running alittle rough.
Often people buy £5.99 for 5litre oils and then complain there is a problem with the engine...:bang:
