Just gave the 4x4 it's first oil and filter change (2,926 miles) I won't be reporting every service but as this was the first (I change the oil on all my cars every 3,000 miles) I thought I would post it. The Biggest part of it was getting the steel belly pan off. "It weighs a tonne". I thought it would be made of plastic but it has definately been made to protect the engine/gearbox over some very rough terrain. It's held with 6 13mm bolts and you have to remove 2 plastic covers over the front bolts held on by self tappers. I would strongly suggest to owners of a 4x4 is to take the bolts out and put plenty of copper ease on them along with the 4 self tappers, as it could prove hard to get off once water etc gets in on the act.
The oil and filter change is a 10 minute job. You do need a strap or chain to take the filter off as there's no room for a filter remover that goes on the end of the filter due to the exhaust shield being so close to the filter.
