How much did that cost?
The charged me £666 for parts & labour.
that is a lot of money for a steering rack replacement, did they do any other work?
unless you plug in scanner and use the full version of MultiecuScan diagnosing it can be hit and miss with power steering issues.
I have had this error several times two old cars
First off its almost impossible to test with a volt meter.
even when the battery is the fault they still measure 14.1 volts when running
One car has had a dead cells and only measured just over 11 volts at rest yet didn't cause the steering light to come on. But did cause other faults including idle and clock issues. Yet a car with 12.4v at rest and 14.1V running did require a battery.
Battery issues normally only happen at slow speed. Normally worse the First couple of turns. If you reversing into a space and the steering fails exactly as you hit the brakes is a dead give away the battery is at fault as is worse the colder the temperature is.
I have had randomly coming on without the steering going heavy due to a slipping auxiliary belt. Mine was slightly worse in wet weather.
juddering, buzzing noise or only failing on full lock is normally not the battery. The First port of call is to disconnect the battery and reseat the steering connector.
For me having two cars makes life easy for me as its just a quick swap of the battery is enough to confirm if its the battery. But reading the code would also confirm a power issue
Check the connector (probably green, blue or yellow loom) behind the steering shroud.
Edit: and the usual steeringcodes are C1002 and so on. If not it could be the alternator as well.
gr J
Yes, battery voltage can cause all sorts of glitches, chances are it will never be an issue again,Just got back home from weymouth, and again no issues. Does this mean it’s more likely that the battery was just a bit low and needed a longer journey to get some charge?
If it has managed 1 week without having issues it was probably just the battery voltage, If you do short distance it will probably happen again but then taking the battery out and giving it a charge will fix it.So how long should I give it before I can safely assume that it was just the battery?
I have the panda as a runabout, kept on the street as the drive is full with my other carsIf the car is not parked on the road, you can charge the battery without removing it from the car.
Another option would be a Lithium booster battery. If it starts with that connected you have the clue. If it's not needed, you'll have a power top up device for your phone, iPad, laptop, etc.
I don't like charging batteries while in the car, unless in a garage with the bonnet fully open, the gas produced while charging can damage paintwork, I might be a bit ocd from my years as a mechanic, and it doesn't take long to remove a battery, and charging in a warn ventilated room is also better for the battery.
I too have an optimate they are great conditioner/chargers, I use it on my R1, what bike do you have?Fair comment but a decent charger should never let the battery get to the stage where acid fumes are given off. But as you say its no big deal to remove the battery and as yours is on the road it can't be done in the car.
I have an Optimate used for the motorbike. I had no power in the garage so couldn't use it for float charging but it was a gentle way to keep the bike topped up. The last bike batt lasted 5 years with extensive periods of dis-use so that was pretty good. I replaced it with a LiFePO4 solid state "lithium" battery which could sit untouched for months without damage. That would have been killed by an Optimate (24 volts boost) but just 4 Amp Hours swung the big engine no problems.
The Optimate recovered old car batteries and more than once got me out of a hole when I really should have just changed the thing ages before.
