Thread Tools
Old 4 Weeks Ago   #1
Ticking and 'chirruping' in dashboard ?!?
Hi all,
I have a 2010 Eleganza. In recent weeks I have noticed some strange noises coming from the dashboard, above the radio. When driving there is a frequent but irregular 'chirrup'. It makes no difference if the radio is on/off, CD player on/off (and I've checked with no CD in the slot too), and AC on/off.
Yesterday I got into the car and noticed that there was a regular ticking noise coming from this same area. The key was not in the ignition and the radio was not on. The noise stopped when I started the car, to be replaced by the 'chirrup'
Any thoughts? Thanks!
PandaEleganza is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
Re: Ticking and 'chirruping' in dashboard ?!?
In view of how damaging low coolant levels are, do check the engine coolant level is correct.
After that all you can do is take things off (bit by bit) until you either find something loose or the noise goes away. I have a groan noise from the steering column area that sounds like something rubbing/vibrating in time with engine revs. Ive got used to it but one day will dig around and see if I can find it.
In your case, its easy to take the radio out and see if anything changes.
DaveMcT is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
Netherlands
Isn't there a cooling fan in/on the radio?
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 4 Weeks Ago   #4
Thanks both...I will have a nose around at the weekend.
Old 4 Weeks Ago   #5
the only thing i can think of that would tick inside the car with engine off is a leak from the heater matrix.
koalar is offline Reply With Quote Quote
Old 4 Weeks Ago   #6
Turn the normal vent fan off and the noise might go away, mine does it especially on speed 1
2009 Fiat Panda Eco Active
2012 Microcar MGO SE, 1998 Reliant Robin Estate
2012 Royal Enfield 500 EFI Bullet
2007 Honda Deauville NT700ABS
2x 1984 GL1200 one with Palma Sidecar
09 johno is offline Reply With Quote Quote
Old 4 Weeks Ago   #7
Well, it's been silent today. Checked coolant, matrix, all seems well. Haven't dared take out the radio but will think about doing this if the noise comes back (it's been on and off for a month, so I imagine it will do).
The odd thing was to have a noise with the ignition off and no key in the slot. This suggested some kind of electrical problem to me. We will see. Maybe I should start thinking about a new Panda...
Old 4 Weeks Ago   #8
Quote Originally Posted by PandaEleganza View Post
you don't have to undo anything to check the matrix.
open the passenger door
pull the carpet towards you from under the plastic trim that's under the gearstick.
shine a torch and look at the area where the bracket from the gearstick meets the floor
If its dropping slightly it will gather here before running under the passenger footwell
Old 4 Weeks Ago   #9
are you sure its not the normal oil dropping back into the sump and you've only must noticed it ?
and the chirping is something else ?
Old 4 Weeks Ago   #10
Don't bother checking the heater matrix. Check the coolant level in the radiator as if that's low you are heading for a blown head gasket. Early signs are funny noises from the heater.
Radio is easy to remove -
Get ta pair of DIN pins for a few .
Push the pins into holes either side of radio and slide the radio out of the dashboard.
Old 4 Weeks Ago   #11
Thanks all. Definitely not the coolant - it was only replaced in February and is at the maximum mark (double checked!). Matrix is dry. I will have a look at getting some radio removal keys.
Thread Tools
(T) Ticking from dashboard area? beacon Barchetta 10 20-10-2009 12:02
(G) from analog dashboard to digital dashboard boukekoppejan Cinquecento / Seicento 9 26-05-2008 14:20
ticking from dashboard, bravo 1.4 Anonymous FIAT Boo Archives 1 11-06-2007 16:15
Dashboard ticking & Sticky Speedo Martin B FIAT Boo Archives 1 06-03-2006 21:06
ticking noise behind dashboard drivers side? ian finch FIAT Boo Archives 2 16-06-2005 14:29
