Hi All
I've just been checking the hydraulic actuator reservoir fluid level on my Dualogic Panda because my gear changes seem very jerky, and been getting a lot of juddering when pulling away from cold. I've noticed that there is hardly any fluid in the reservoir, just a dribble right at the bottom. I didn't open the drivers door, so have not allowed the hydraulic actuator pump to run.
Is this normal, or should the level be visible in the reservoir? I personally couldn't see any max / min markers on the reservoir.
If it does need topping up, is it ok to just top it up as you would any other fluid level or is there a special procedure that needs to be followed? I know the oil that's needed, just need to know the topping up process.
The main worry though, is if the hydraulic fluid level I've got in my Panda isn't normal, then where has the fluid gone? I've noticed some wetness underneath the engine, around the casing linked to the driveshaft.
Any thoughts, help and advice on this would be really appreciated.
