Rockrabbit
- Dec 9, 2015
- 13
- 5
Is it just me or is my 100hp not as quick as it used to be?
87k miles. Serviced as per schedule.
Had timing belt replaced recently - thought the timing could be bad, but I returned it to the garage and they confirmed all was in order. It also accelerates smoothly and idles just fine, so it probably isn't a timing issue.
Its almost like the "sport mode" is not working (not as sensitive throttle as it used to be). But the sport button still makes the steering stiffer and there is a slight change in performance, so the sport mode must still be working.
The dampers need to be replaced - Could it be that the suspension is dulling the ride a bit?
Anyone else with a similar experience who can shine a light on what it might be?
