hello does anybody know if alloy wheels from a fiat Multipla will fit a panda cross please 2001 6j15"PCD - 4x98, Offset ET31.5, 6.5J wide.mine is 15" 2010 what is the pcd offset for my car.
On my Panda 100hp the Punto wheels I have are 35mm offset and have no effect on the brake calipers etc.
However - for you to use the Multipla wheels on your Panda Cross you might be best adding some 7mm spacers to get the offset compensated(and will need longer bolts).
Thanks for all the advise chaps,will have a look at the chart and see if I can work it out,all I want to know is what outher fiat 15" alloy will fit straight on without spacers or bolts,i want to put some proper snow tyres on for the winter and keep my cross wheels clean.could get a set of 4 form a breakers yard if I new what outher fiat car will go straight on.
what outher fiat 15" wheel will fit straight on without the use of adaptors.will these go on 6J X 15 H2-43 on ebay item number is this 300948003999 that is what is on the back of these wheels the same as mine but for the 43.
