Thread Tools
Old 28-06-2010   #1
Cold air feed for standard airbox
Since i've had the panda there has been one thing thats annoyed me and thats the lasck of air the intake pipe is getting, if you have a good look you'll see that there is no way of cold air getting to it what so ever and this can't be good on these hot days.
So today after recieving my new front grill (other one was cracked) i decided to see if i could route some sort of pipe to the end of the intake pipe and heres what i came up with
The biggest pipe i could get in there was 50mm but for this size engine i think that is big enough anyway.
I've not long come in from testing it out and i noticed that it feels stronger low down the revs and the pull just stays there till 7k without any drop off in power whereas before it felt kinda limp above 5k.
Still got the standard filter in at the moment but i will replace that with a K&N replacement or similar.
I know most people go for the GSR but IMO i don't think this engine could cope with an open filter because of the lack of cold air. Tempted to go with the BMC CDA but not sure how big the filter is inside of the carbon casing,
would it be better than the standard airbox with a replacement filter and a decent cold air feed? I don't know.
But for now this feels just fine and very happy with the way it pulls, just need to get rid of that annoying vibrating sound coming from the dash above 5k
Thanks LeanMeanRacing thanked for this post
robjnr is offline Reply With Quote Quote
Old 28-06-2010   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Cold air feed for standard airbox
Will be interesting to see if it makes much of a difference.
Will also be interesting to see how soon it is you get water into the engine once the puddles arrive
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 29-06-2010   #3
panda active comes with cold air feed as standard haha, the air box is on top if the engine (like the 100hp i think) but it has a small pipe that takes its air feed directly right behind the front plastic grill
pandasam is offline Reply With Quote Quote
Old 29-06-2010   #4
Trader Rating: 2
Quote Originally Posted by pandasam View Post
Just like the 100HP, and just behind the grille isn't the coldest of intake points
Old 29-06-2010   #5
its not bad though
when your zooming along it must draw in reasonable temp air, but i reckon in this hot weather your unlikely to draw much if any cold air in, unless your up at 3am where you can draw in luke warm air
Old 29-06-2010   #6
If you look at where the original cold air feed pipe is, it is completely inclosed, due to the honey combe grill at the front being solid. Also that plastic thing that I cut a hole in stops ALL air getting to the filter. Regarding water I never put my foot down going through puddles any way, and the standard pipe has a section where it catches dirt and water so it stops it getting to the filter
Old 29-06-2010   #7
was it hard removing the front bumper?
Old 29-06-2010   #8
Not hard mate but a little tricky. The trickiest bit is trying to get to the 2 screws behind the wheel arch liner on both wheels, but if you unclip the plastic trim on the side of the front bumper then it gives you a little bit more room and doesn't shread your arms as much lol. Other than that there are 4 hex type screws underneath the bumper and 4 nuts on top and then it will literally fall off. But don't forget to unclip the fog lights
Old 29-06-2010   #9
Looks like a great solution!
I have always noticed that there seems to be a lack of air being fed to the airbox due to the construction of the front bumper.
Panda 100HP OEM+
S-X-I is offline Reply With Quote Quote
Old 29-06-2010   #10
My thoughts exactly, cannot be good for performace.
Can't believe how much difference it has made, it feels like a different car to drive.
I said it earlier but the response you get when you put your foot down is awsome, sport mode off now feels like it did before when sport mode was pressed (but without the jurkiness), sport mode on now feels wicked
Old 29-06-2010   #11
1985 AE86 Sprinter Trueno
trackdayqueen's Avatar
trackdayqueen has donated!
I did have a good look at the air intake after seeing what you have done.
About a year ago my intake piping from the grill decided to part company, so I spent a week or two driving around with no intake piping to the filter box.
Now I know people talk about 'cold air feeds' but really it's not cold air at all, it's ambient air.
I really remain to be convinced that say if the under bonnet temperature whilst the car is moving is say 20 degrees hotter than the ambient outside temperature that it will make any discernable difference to performance. I say this due to a number of experiences testing intercooler inlet and outlet temperatures using probes years ago on a bit of a modified mr2 supercharger I had. I found that until the outlet temp of the intercooler went above 70 degrees C, it didn't seem to impact on performance. Also it's worth remembering that the air will heat up on it's journey to the engine itself, which stands to reason really.
When my intake piping fell off, I found that the car sounded better, I guess you'd call it a more rorty, but I didn't notice any real difference that I could detect in performance.
Now, coming back to the way the intake is configured, it definitely does seem odd that there isn't any obvious airflow points towards the air intake. It would seem that the plastic panel above the radiator is there to ensure airflow through the radiator. So when it comes to the intake effectively it relies on all the air gaps around the panel, around the headlights and airflow that goes between the bonnet and grill. I agree it does seem compromised, though I'm not overly convinced as to whether it is.
A more effective solution I might feel is to cut out some of the honeycombs offset to the intake (so as to prevent any water ingress). I'm a bit puzzled as to why not that is the case as standard. I'm sure on lesser models the grill is perforated and you have to wonder why it isn't on the 100hp.
2008 Red Panda 100hp - Sold May 2011
trackdayqueen is offline Reply With Quote Quote
Old 29-06-2010   #12
I did this same mod to one of my - don't laugh 126 bis's, result was, it went considerably quicker and mainly being top end, so much so it went off the clock, 90 mph !!!
On private ground of course
Nuff said.
randysbits is offline Reply With Quote Quote
Old 29-06-2010   #13
Quote Originally Posted by randysbits View Post
Nuff said.
OFF THE CLOCK AT 90?!?!?!?!? LMAO!!!! that is brilliant, a speedo that ends at 90 lol
ive only ever owned 2 cars, a 1.1 metro and a 1.1 panda (stick to what you know) the metro had 130 mph clocks (changed them from the 110 clocks it came with so i had a rev clock) and the panda has clocks over 100, cant remember the exact speed they go too.
what was the official top speed of your 126?
Old 30-06-2010   #14
Trader Rating: 2
120 on the Active
Hmmm, wondering if its possibly worth doing this on the Stilo
Old 30-06-2010   #15
i think my tyres are rated to 150 so i reckon the 93 fiat claim the panda can do is safe
Thread Tools
(T) Cold Air Feed cash_123 Punto (Mk2/2b) 27 09-01-2008 13:40
(T) Cold air feed chegers Cinquecento / Seicento 26 16-10-2007 14:44
(G) Cold Air Feed Newboi Cinquecento / Seicento 8 26-02-2006 18:21
(T) Cold air feed... arc Cinquecento / Seicento 10 18-09-2004 23:55
(T) Cold Air Feed. carlloughney Bravo / Brava 5 04-06-2004 01:43
