Some laws of physics:
Longer total length of tube = more flow resistance to air moving through it
and more bends = more resistance to air moving through it
and rough inner surface = more resistance to air flowing through tube
(try blowing through a short length of garden hose: easy. Now, try a complete roll of hose: can't do it. Same laws in action)
Each one of these is a criteria considered in fluid dynamics, and the degree of reduction in flow rate and pressure is determined by Bernoulli's principle (its a long time since my Chemical Engineering HNC, but this might help explain:
http://en.wikipedia.org/wiki/Bernoulli's_principle). And the phenomemon of pipe friction is covered here:
http://www.efunda.com/formulae/fluids/calc_pipe_friction.cfm
So, in theory, your mod should actually make things worse. (A short, straight and smooth-bored air intake should, correspondingly, show a significant improvement)
But, you may be countering these flow losses by the 'ram effect' of the air being pushed into the pipe as a result of the car moving forwards. At speed, this effect could be pretty significant (similar in some respects to adding a turbo- or super-charger). But off the line from a standing start, the effect should (in theory) be minimal.
As to temperature, I doubt the air immediately in front of the car is any cooler that the air immediately behind the grille when the car is moving -- the effects of a wind blowing through the under bonnet space at 50mph will mean its all pretty well the same temperature. But in traffic it could make a degree of difference.
But, in spite of all that, a neat job done well. And it makes you happy, which is what you set out to become
