Is there an idiots guide?? When I try to connect I just get an italian lady shouting at me!
My old-but-faithful Sony Ericsson P910i connected first-time and yet when I got a Nokia N97, it would never pair. After that phone froze and then was subsequently fixed by Vodafone, it now connects to the Panda.
For the N97, I ignored the manual as I was away from home at the time. This is what I did:
- Have phone's Bluetooth enabled and visible to other devices
- Turn car's ignition on
- On the phone's Bluetooth settings, search for devices
- If it finds the car 'Phone v3.15' select that
- Enter passcode '1234'
- Phone and car should pair
I think that's it?! If necessary, I can refer to the manual.
The maunal is AWOL... hence my trouble. Would appreciate a note explaining any of the key steps. And yes, it's a Nokia.
That's exactly the same problem I had when I first tried to pair the N97. What phone are you using, Dan?
You can try clearing the memory by holding the green and red phone buttons for min. 2 seconds and then try pairing once again.
I gave up with the N97 and it was only after it had the software upgraded by Vodafone that it paired. To be honest, I rarely answer as I don't like driving even with handsfree. However, it's good to have everything working as it's meant to.
It's a Nokia 2700, and I'm giving up!
By the way. A N97 is still a big issue. The phone still doesn't work the way it should. I recentley have sent 15 N97's back to our supplier because of softwere problems. All with the same problem.
