Okay, have been waiting a while to try this. I took the 100hp for a couple of laps at Anglesey, just to see what it was like handling wise and explore a few different possibilities.
In the fastest bend on the national circuit the car actually felt quite well balanced, my partner stated that it felt twitchy, but to be fair though I was having to adjust steering input a little just to balance it, it did go round at a fair rate and seemed to close on a caterham (which surely couldn't have been driven that well) in the middle of school.
This was all well and good but it was in the slower bends that the 100hp really suffered. Its propensity to lift an inside front wheel really seems to be its achilles heel. As a result trail-braking as such really does go out of the window so to speak. The problem is that getting onto the brakes seems to cause the ABS to activate due to the inside wheel being in the air I guess which effectively means you ain't going to bring the rear into play as all it does is understeer. Don't get me wrong its not terrible and for such a cheap car it copes reasonably well, it is a shame though.
It seems that no matter what you do short of yanking the handbrake (which I didn't try) that you will not invoke oversteer. The only possibility of it is in the wet where you may be able to keep both front wheels on the tarmac and apply the brakes with some more effect.
I must admit after finding this out I do wonder why anyone would bother with ESP as surely it is simply a waste of money given that the wheel lifting combined with ABS stops any tail out antics anyway.
All said and done it was reasonable fun and it did perform quite well, not feeling stupidly slow. Through the one decently fast corner it was actually pretty good. The other thing though that let it down was the rubbish Eagle F1's. Great on the road, utterly useless on the track. I only did a couple of laps because I feel them starting to overheat which just made the understeer worse. A tyre with a stiffer sidewall would undoubtedly help I think, not that i'll be on track in the 100hp again.
