grizzly_panda
Yeah the oil looks fine
Bad design of the GSR kit I guess, that is my point.
The difference is, if it happenned on a standard car you'd have your warranty.
Sounds like to me that the GSR kit is a liability.
The knocking noise just sounds... tappety is the best word I can come up with to describe it, tappety in the extreme:yuck:
Sorry to hear that. This is the problem with fitting aftermarket parts which haven't had the benefit of proper development.
That is an appalling oversight.
In summary:
http://www.standardisbetter.com
is there a photo of the puddle? as it sounds more like a flood to me
You know what it was more like a flood, I don't even know why I used the word puddle, maybe because I'm not used to there being much more than a puddle around here when it rains heavily. I should have said gargantuan puddle or a flooded road yeah
If you read the post properly you possibly would have picked up that a Rover was in front not running anymore. I very much doubt that the Rover has got a GSR induction kit.
In all the induction kits sold, this is the third time only that water ingression happened. The other mentioned case was in 2 foot deep water, where the car came after about 100 metres to stand still. Any induction standard or not would have suffered from water ingression.
When driving through water that is deeper then 3 to 4 inches a certain way to drive through is needed if they are not avoidable.
i ain't running a gsr but on my car the intake is low, i carry a screw driver, so if i ever do come across an unavoidable flood i would disconnect induction and use a sock until i was at the other side, but normaly i just go another way
wouldn't call it poor design, its common sense that if you change induction to a low feed one then you don't drive through a flood with it.
if you want induction for floods then you install a snorkel system
I'd be very supprised if you could claim anything (insurance or warranty) for driving through water
Must admit it seems a bit poor to me if you have to carry a screwdriver around just in case you encounter a puddle that is too deep!!
on the way to and from a few meets this year the rain has been very heavy with a lot of surface water, i had no problem, nor did stu with his 100HP and gsr kit
