if only Adobe made cars then you could be living the dream!
Don’t fancy an annoying subscription lol
4 cylinder engines are generally seen as more refined than 3 pots. Probably not so much the case nowadays, but certainly in the past.
This new info make more clear about the Orange Panda mule in resend pictures.
That car has the rear exhaust silencer from the 1.2ltr FIRE and a intercooler.
It would be plausible to think that this mule is already running the new 999cc, 3 cylinder, MultiAir turbo, GSE-Firefly engine, whit ± 100 hp.
You mean the ones that look like they have the same cooling behind the grille as a twinair Panda?
Weird that they say 'without Opel'. The engines that Fiat used were co-designed with Opel at FPT as far as I'm aware. The only joint developed one they used in the Panda was the 1.3 diesel. The article implies that without Opel they'll have some disadvantage. Not sure what that would be - unless it's one less customer for the 1.3 and 2.0 diesels.
I never realised that Fiat actually worked with Opel to develop any engines at all!
It’s a test mule, it’s not really indicative of anything.
You’re making wild assumptions based on nothing more than your thoughts. As someone who is currently working to deliver a new car, lets just say a lot of rumours and assumptions that people make are totally incorrect.
A new engine COULD result in a new exhaust layout, or it could be a number of things.
You were talking about an A segment car having a 1.8 litre engine, that’s simply NOT going to happen.
Yeah, I knew about the platform sharing, but I thought all the engines were Fiats own, mainly various versions of the FIRE, with the 1.3 multijet being a diesel version of the 1.2
