FIAT Auto Specialist Team
Old 31-03-2004   #1
low, very stiff, clutch pedal
Just got a Panda on Sunday. Very clean, well taken care of, full service history, 49K miles. The clutch pedal is very low, maybe 1 1/2 inches of travel, and must be really pressed hard to disengage and shift gears. The cable looks new.
1) What is the most likely/least expensive problem (I'm thinking stretched from previous use and rusty from sitting)
2) Renewal sounds easy enough from Haynes manual- any hidden secrets/hints?
3) Ballpark cost of a cable?- My Canadian accent in Wales means the locals keep trying to rip me off, thinking I'm a Yank.
Cheers,
Justin
toecutter is offline Reply With Quote Quote
Old 31-03-2004   #2
2 words, buggered clutch.
Possibly about 100 fitted price. Only a rough guide though.
Pete
K&N Induction Kit On A Panda?? Never!!!
pete1nlancs is offline Reply With Quote Quote
Old 31-03-2004   #3
I'd tend to agree with Pete about the clutch:(
The new cable suggests the old one broke because of the effort needed to operate the clutch:
looks like you found out why it was for sale...
Travel is quoted as 127mm in Haynes - about 5 inches in English - it is adjustable with a nut on the gearbox end of the cable.
May just be rusted up through lack of use, but I expect you'd need to get it to bits to free it off, so a new (maybe 60 UKP) clutch while you're there is probably the best answer.
John H is offline Reply With Quote Quote
Old 31-03-2004   #4
Cheers, Pete. I think. Just what I like in written communication: conciseness and colour. However, could you elaborate on which part of the clutch (pressure springs?) and the technical description of "buggered"?
Cheers again,
Justin
Old 31-03-2004   #5
Quote Quote:
Possibly the actuating arm pivot, or the driven plate sticking on the gearbox shaft splines. Unless anyone else knows different.
According to my Concise Oxford dictionary...:)
Bugger: (often foll. by up)
a - ruin; spoil (really buggered it up; no good, it's buggered).
b - (esp. as buggered adj.) Brit. exhaust, tire out.
Old 01-04-2004   #6
rrockettman has donated!
I've had a similar thing with one of mine in the past. It was the actuating arm sleeve that runs over the spindle, that was worn. The sleeve only cost a couple of pounds but you need to seperate the engine and gearbox. If you're doing this, you might as well replace the whole lot, release bearing, clutch and plate. A LUK replacement kit is around the 30 mark I think.
Happy Pandering.
Russ
rrockettman is offline Reply With Quote Quote
(T) Strange Clutch problem Julio_Scorchio Cinquecento / Seicento 21 16-11-2008 02:02
(T) Wind noise & creaking clutch pedal Squadrone Rosso Stilo 29 21-06-2006 23:35
(T) Clutch - cable or clutch itself? SnowBord Cinquecento / Seicento 12 13-02-2005 17:18
(T) Clutch pedal The younger modder Cinquecento / Seicento 2 22-03-2004 03:43
(T) Tipo clutch pedal mystery Paul Tipo Tipo (Classic) 1 01-10-2003 04:24
