im Axle Specialists
Old 21-01-2007   #1
Camshaft question please.
I have seen on this forum somewhere, reference to the part numbers for the standard 999FIRE camshaft and the 999FIRE camshaft used on the engines fitted to the 4X4 models.
Assuming that I have two camshafts ( one of each ) is there anything on them or about them, which would confirm which is which ?
Thank you. Petel
petel is offline Reply With Quote Quote
Old 21-01-2007   #2
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Camshaft question please.
If you had two, one of each, the one with the larger cam lobes should be the 4x4 one....
More Rock!
Less Roll!
Sprox is offline Reply With Quote Quote
Old 21-01-2007   #3
Trader Rating: 2
allen fletcher has donated!
Quote Originally Posted by Sprox View Post
Hi Richard ie Urchin pointed out to me that the 4x4 cam has it stamped on the cam shaft between two cams easy to spot he did a head up for me off a 11000cc auto that had a 4x4 cam fitted
allen fletcher is offline Reply With Quote Quote
Old 21-01-2007   #4
Thank you both very much for the confirmation.
Rgds, Petel
Old 21-01-2007   #5
eh?
Trader Rating: 1
Tony M has donated!
yeah, it's stamped on the cam. it cleared up the question of what cam is fitted fairly quickly.
Tony M is offline Reply With Quote Quote
Old 21-01-2007   #6
eh?
Trader Rating: 1
Tony M has donated!
Quote Originally Posted by allen fletcher View Post
ooohh, was there a difference in performance once the 4x4 cam was fitted?
Old 22-01-2007   #7
must have been good performance for the size of engine 11 litres!! (see quote above)
Currently owned:
54 plate "New Shape" Multipla & Panda
"Better a bad day on the Track than a good day at the Office"
petebarchetta is offline Reply With Quote Quote
Old 22-01-2007   #8
eh?
Trader Rating: 1
Tony M has donated!
Quote Originally Posted by petebarchetta View Post
they can be a bit of a handful the autos
(T) Camshaft front bearing worn??? jonti Tipo (Classic) 13 08-01-2007 11:30
(G) Donald, Friends! One more question. Camshaft timing belt settings. Phoma Ulysse 2 11-12-2006 09:52
(T) Air Pressure Sensor, Camshaft change? MadBravaDriver Bravo / Brava 2 19-02-2006 22:58
(T) camshaft question jami Punto (Mk2/2b) 3 18-02-2006 20:01
Answering The Previous Question Dr_Pepper Leisure Lounge 35 25-11-2004 15:25
