We're taking our Fiat Panda (Pinky) right th way across the Sahara Desert on the Plymouth Banjul Challenge.
Apparently the border guards take your V5C registration document really seriously, particularly the engine & chassis numbers, which they cross check against the car. Our chassis number is fine, matches the V5C no problem. The engine number is a different matter.
According to the V5c our engine number is K33/5250 the chassis plate says the engine is 156A2.246 and according to the gospel according to Haynes
"the engine number is stamped on the cylinder block coolant pump housing at the front of the engine above the oil filter cartridge"
No sign of the wretched thing, Ive cleaned wire brushed twiddled and stared in all sorts of different lights to no avail. Just a rusty expanse of cast iron.
Is it anywhere else on a Fire engined 1000cc Panda?
Which of the 2 numbers sounds right K33/5250 or 156A2.246?
Any advice on what I should do to re-instate the engine number?
Thanks in advance
Culpitt
Thanks in advance
Culpitt
