[FONT="]Hi All,[/FONT]
[FONT="] [/FONT]
[FONT="]Just given the Sisley a little service and on its first run since it’s developed a couple of issues:[/FONT]
[FONT="] [/FONT]
[FONT="]Firstly; I now don’t have the ignition warning light (battery light) before starting the engine - just the oil pressure light that goes out once started. And the temp gauge has stopped working. I’ve previously done all the earth points and it was working fine before the service.[/FONT]
[FONT="] [/FONT]
[FONT="]Secondly, the engine now cuts out when off choke and off throttle. It will idle with the choke out but not in when up to temp. When you switch the engine off it tries to run on (possibly because the choke is out?). I’ve checked the solenoid on the distributor and I can pull a vacuum on it. The carb solenoid clicks when you put the wire on to it with ignition on: so I believe both are working.[/FONT]
[FONT="] [/FONT]
[FONT="]Not sure if I have disturbed something doing the service? I did oil + filter, inline fuel filter, air filter and plugs.[/FONT]
[FONT="] [/FONT]
[FONT="]Anyone got any ideas of what else to check?[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
