Thread Tools
Old 14-03-2019   #1
Trader Rating: 1
Lumpy idle and stalling
I've been daily driving the Panda recently, great to be back behind the wheel again, it runs pretty nicely but my bug bare is a lumpy, hunting idle and prone to stall at lights. This is an ongoing problem, I found an old thread of mine from 2008, but it wasn't even starting then so the idle didn't get fixed!
I increased the idle slightly and it hunts between 900 and 1200rpm when warm. Vacuum is new by the way. Just becomes a pest around town as I need to leave the choke half out to stop it dying at the lights, usually just as they turn green!
Any tips for what to look at? It is overdue a service so I should maybe do that first.
Ta.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
nitro_warrior is offline Reply With Quote Quote
Old 20-03-2019   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Lumpy idle and stalling
Yup, service would help, but it sounds like a vacuum leak.
The fact you can sort it by adding fuel (choke) suggests too lean when choke in.
D
Old 25-03-2019   #3
Spirito di Panto!
Palio's Avatar
Palio is part of the official FF Events Team :)
Palio has donated!
Animal Maze Champion, Baker Champion, Bunny Grab Champion
Have you snipped off the idle control valve thing yet? It might be that.
Many Pandas have been cured by Verns snip so to speak - ask @VmanC for tech instructions as he did mine!
Please support Pinky - go to http://www.easyfundraising.org.uk/causes/pinky
Palio is offline Reply With Quote Quote
Old 25-03-2019   #4
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Race to Excel Champion
As Palio suggests, itís probably the fuel cut off solenoid (aka anti run on solenoid). If itís not working it will be permanently shut cutting off the fuel in the idle circuit. They were fitted because poor fuel quality in the 80ís caused the engine to run on briefly after switch off, when the ignition is on they should be open. Fuel these days is better so they are not needed, therefore itís ok to cut off the needle plunger so they remain permanently open.
P.S. The choke is working for you at the moment not because itís enriching the mixture but because it also increases the idle enough to draw fuel from the main circuit. Iím not ruling out an air leak entirely but the solenoid is the most likely culprit.
Thanks Palio thanked for this post
Likes Palio liked this post
VmanC is offline Reply With Quote Quote
Thread Tools
(T) Uneven idle, stalling from idle, Engine knock when revving Kake 500 4 14-01-2016 10:50
(T) GT Lumpy idle Eklipze3k Punto (Mk1) 38 17-03-2014 19:32
(G) Running lumpy/Idle lumpy Mikeyboyfiatpuntogtlover Punto (Mk1) 5 21-08-2012 23:22
(T) Abarth lumpy idle and stalling... Donkey Stilo 53 17-08-2009 18:00
(T) 1999 Punto - Lumpy Idling and stalling Anne-Marie Punto (Mk2/2b) 0 02-12-2005 10:14
