Technical panda carb
Marti155
Member
Forres
Hi I have a 1992 fiat panda 750. The carburetor has been playing up and I am having problems finding a re-build kit. it's a Webber 32tlf. I do have a spare Webber 32 icev that came off a 1990 uno that I know is good and works fine. My question is what is the difference between the two carbs is it just the jetting or are the venturie different as well. Thanks again for any help.
If its a 999cc Uno then it's the same carb with different jetting. I think all other Uno engines probably had quite different carbs, although I know very little on that.
I'm sure you'll be able to find a rebuild kit somewhere, maybe check the parts thread in the sticky section?
No the 999 Uno had the same 32tlf as the Pandas, ICEV is off a different engine and a completely different carb. How much might be interchangeable I don't know but things like gaskets & diaphragms would be different, venturi don't know, jets some maybe. It'll be a case of getting lucky some parts are the same rather than there's the odd difference.
If you're looking at fitting it rather than just cannibalising for parts, offer it up and see, if you can get it on and connected up, it'll probably run. How close the jetting is depends really which engine it came off, carb from a 1.3 or something is likely to be a bit out, might give you a bit more poke even but not great for squeezing through at MOT time. The challenge will be getting the fuel inlet, choke and throttle linkages all to marry up and persuading it onto the inlet manifold.
hi thanks for the info I am going to have a good look and try to fit the ICEV carb on the panda. The carb came of a 1990 fiat uno with a 986cc engine and a 4 speed gearbox. As far as I know it was the 903cc push rod engine uno that are ment to have the ICEV carbs. I may well be back for a re build kit. but if the ICEV carb fits and works it will do to keep the car going at the moment. Thanks again
