Thread Tools
Old 03-07-2014   #1
Big is not always better
scout's Avatar
scout has donated!
Question Door internals
I have a weird problem with the drivers door on my 1986 Panda. Every now and then the door won't lock on the key. As I have changed the key barrel I can only conclude that some of the internal connecting rods are not sitting/working correctly but with limited access and big hands I am having difficulty tracking it down. Any suggestions gratefully recieved.
What I could do with is the internal workings of the door lock mechanism (I have a brand new catch to fit). It always locks on the plunger.
Has anyone got all the internal rods available from a scrap door that I could obtain?
Gotta' luv goin' topless
Be wary of little Fiats they get under your skin
My 500 has an older cousin (Classic Panda)
scout is offline Reply With Quote Quote
Old 03-07-2014   #2
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Race to Excel Champion
Re: Door internals
There are only two rods in the door, a long steel one from the inner door handle to the latch, and a short plastic one from the outer lock to the latch. If everything works sometimes they are probably ok.
The latch has all the other components on it so it's worth removing this and making sure that nothing is broken and moves freely.
If you need another latch I've probably got one you can have.
Thanks scout thanked for this post
Likes Dragon Man liked this post
VmanC is offline Reply With Quote Quote
Old 03-07-2014   #3
scout's Avatar
scout has donated!
Re: Door internals
Quote Originally Posted by VmanC View Post
What does the internal lock button operate on? as this always works
I have bought a brand new latch (from partsworld) which arrived yesterday so I will fit that and see what happens do I need to dismantle all the bits to change it or can it be done from the outside?
Thankyou
Old 03-07-2014   #4
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Re: Door internals
Quote Originally Posted by scout View Post
Thankyou
Ah yes, the internal lock button, make that three rods. It also operates on the latch so you should be sorted with a new one.
You will need to take the door trim off, don't lose the clip for the window winder, it has a habit of flying away out of sight. You can attach it to the winder handle before re-fitting then just push the handle into place.
With the door trim out of the way you can detach the three rods from inside the door, then unbolt the latch assy. Again, be careful not to drop the plastic clips that hold the steel rods into the bottom of the door, they are almost impossible to get back.
Old 03-07-2014   #5
Spirito di Panto!
Palio's Avatar
Palio is part of the official FF Events Team :)
Palio has donated!
Animal Maze Champion, Baker Champion, Bunny Grab Champion
Re: Door internals
Stop removing Po's character Bob! It's just one of those loveable foibles - it always locked from the inside & then the key worked again - abracadabra!!
Likes homeward, VmanC liked this post
Please support Pinky - go to http://www.easyfundraising.org.uk/causes/pinky
Palio is offline Reply With Quote Quote
Old 03-07-2014   #6
Trader Rating: 1
Re: Door internals
Good tip!
Also if you do drop the plastic clip tape a ball of duck tape with the sticky side out on to a pea cane and use that to go fishing. Make sure you tape the stick ball of duck tape on securely other wise you will have a stuck ball of duck tape to retrieve too.
... Not that I have ever lost the plastic rod... no....
Likes Didge3, homeward, VmanC liked this post
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
nitro_warrior is offline Reply With Quote Quote
Old 03-07-2014   #7
Brain stopped play
homeward's Avatar
Trader Rating: 1
homeward is part of the official FF Events Team :)
homeward has donated!
Re: Door internals
Quote Originally Posted by nitro_warrior View Post
Yet another vitally important item to add to the ever-expanding range of Classic Panda tools!
1990 Panda 750L Formula '90: Pippin (26,131 miles; 47.18 mpg)
2009 Panda 1.2 Eleganza Dualogic: Pandora (55,670 miles; 47.87 mpg)
2002 Punto 1.2 16v ELX Speedgear: Priscilla (100,465 miles; 41.30 mpg)
homeward is offline Reply With Quote Quote
Old 03-07-2014   #8
scout's Avatar
scout has donated!
Re: Door internals
Quote Originally Posted by Palio View Post
Personally it doesn't bother me but every day I get ear ache from my daughter who doesn't want to climb across from the passenger seat (its getting more frequent). If fixing the latch gives me some peace and quiet then Po's character will go
It will get some roof mouldings and a n/s door pocket as well (I sort of splurged at parts world)
Thread Tools
(T) 4x4 Gearbox internals. C.McMorran Panda (Classic) 29 18-10-2019 20:40
(T) Airbox internals Gavv8 Panda 2 02-02-2014 19:00
(T) Engine Internals Cleaning richydraper Stilo 3 29-08-2012 01:01
(G) Hot to identify the internals of your engine Abarth 695 500 (Classic) 3 13-07-2012 09:16
(T) 6 speed internals fordy Cinquecento / Seicento 24 18-07-2004 00:25
