FIAT Auto Specialist Team
Old 24-04-2011   #1
benjii has donated!
Angry coolent problem!!
I noticed that my temp dial wasn't working but the fan was coming on, so thought change the temp sensor, changed it today and still not working and fan not coming on but getting hot the sensor was of a engine i have not a new one but looked newer than the one i took off i am lost what to do now other than by a brand new one and fit that...
any ideas/ help?
Thanks all benjii
benjii is offline Reply With Quote Quote
Old 24-04-2011   #2
panda1408 has donated!
Re: coolent problem!!
There are two different senders for the guage and fan. The guage sender is on the back of the block behind the oil filler, so that is the one you need to change.
What car is the spare engine out of? If its not a Panda then the sender probably has different resistance values so it will be no good.
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 24-04-2011   #3
benjii has donated!
Quote Originally Posted by panda1408 View Post
thanks for that so if i change that sender it should work hopfully , what about the fan not working?
and yes the engine was off another panda 4x4, going in my next project ha.
any other ideas anyone
Old 24-04-2011   #4
Im presuming you changed the fan switch then? Put the old one back in and then the fan should work.
1982 Panda 45
Old 24-04-2011   #5
benjii has donated!
nope all i have changed is thermostat because the dial wasn't working on the dash but now dial is still not working and fan doesn't kick in
Old 24-04-2011   #6
Oh, is it all bled and filled up properly, the coolant level might not be high enough to reach the switch therefore it wont work. Is the heater working?
1982 Panda 45
Old 24-04-2011   #7
Serbia
Check the wires,perhaps there is a break in the wire lines
rele is offline Reply With Quote Quote
Old 24-04-2011   #8
benjii has donated!
yes the heater is working fine nice and hot and yes its filled up to the right level and the 4x4 is self bleading am sure... plus i have squeesed the pipes to try and get any air out if any
Old 24-04-2011   #9
benjii has donated!
Quote Originally Posted by rele View Post
i checked the connections on the fan rele but dident back track them
Old 24-04-2011   #10
Seems odd, have you tried shorting the connectors on the plug to see if the fan comes on? Actually where exactly is the fan switch on a 4x4??
1982 Panda 45
Old 24-04-2011   #11
Serbia
Have you try to connect fan directly to see if it is faultless.
P.S panda 1408 you are faster then me.
Old 24-04-2011   #12
benjii has donated!
Nope i havent tried that, electrics is my downfall and the fan switch is next to the fan really on the side of the radiator
Old 24-04-2011   #13
benjii has donated!
nope i havent done that, its just weird that the fan and dial on dash wont work
Old 24-04-2011   #14
Serbia
Then try to change temperature relay-fan switch.
Before your job dash dial was good?
Old 24-04-2011   #15
benjii has donated!
Nope the dash dial wasn't working then so my first thought was the temp switch underneath the dizzy cap but still not working
(T) Coolent Bleeding? Grim_Evil Grande Punto 5 09-03-2013 17:25
(T) coolent problem Grim_Evil Grande Punto 8 01-12-2010 21:14
(G) What coolent do you use? MadMan0 Punto (Mk1) 3 07-06-2010 16:47
(G) Coolent loss FRESTER Multipla 0 30-12-2009 12:25
(T) Coolent Silver_Sei Cinquecento / Seicento 2 14-09-2003 04:32
