Thread Tools
Old 02-11-2009   #1
Fiat 124 SC AC 1600 - early cooling system = failure?
Hi!
I have a problem with overheating.
Haynes tells of a early and a late cooling system, I'm guessing my 1600 should have the late system but the early one is installed.
The main difference is the placing of the thermostat, in the early system it's placed before the water pump and on the late it's placed at the top outlet(or inlet?).
With disconnected hoses the engine wants to flush out water from the top of the engine when it's running.
It seems the placement of the thermostat is going to block water from going to the radiator far beyond the time it should.
So should I just connect a late cooling system? Will it solve the overheating problem?
Thanks in advance
//Filip Arvidsson
Filip is offline Reply With Quote Quote
Old 03-11-2009   #2
Re: Fiat 124 SC AC 1600 - early cooling system = failure?
Another question:
The seal/cap on the radiator is is connected with a spring that pushes the sealing down, and releasing at high pressure. Above the spring sealing the expansion bottle is connected, is this correctly connected?
Shouldn't the expansion bottle be able to fill the radiator? Now water should be able to pass the spring seal when going out of the radiator.
Should the expansion bottle be sealed or open?
Old 04-11-2009   #3
Expansion bottles also have a cap but it is not usually a pressure cap on this design of system. The radiator cap is indeed a pressure cap and allows coolant out above a certain pressure into the expansion tank and back into the radiator when the pressure drops. Remind me again what symptoms are you getting that lead you to the conclusion that there is a fault?
I love old Fiats! 130, 131, 132 and Argenta cars and parts always wanted!
mirafioriman is offline Reply With Quote Quote
Thread Tools
(T) cinquecento cooling fan doesn't cut in early enough pm215 Cinquecento / Seicento 29 12-08-2011 18:28
(T) HELP! Punto 1600 pressurising cooling system!! alibob2 Punto (Mk1) 4 29-01-2009 10:52
(G) How do i fill and bleed the cooling system on a FIAT BRAVA 1.4 SX R reg astaroth26 Bravo / Brava 4 31-03-2008 20:31
(T) 1968 124 Early rear drive shaft spidernuts 124 Spider (Classic) 1 16-10-2007 08:18
Cooling Fan 124 Semba Lets Talk FIAT 0 09-10-2005 14:16
