Not only will you need to uprate to an electric fuel pump, but you will have to pay careful attention to where you mount it. Handbrake turns will starve the pump if its in the wrong plce.... BTDT
I used 2 x 1.5litre a min pumps in my rally car, mounted one on each side, had fuel pickup each side at bottom of tank (8mm, 5/16"), then ran them together into a Y piece that went (3/8",10mm line) to the front of the car, fuel pressure regulator set at 3.5 to 4 psi, and a (1/4",6mm) fuel return line back to the tank.... in the T that you put the return line into.... braze up the 6mm spigot, and drill a tiny (2mm) hole to restrict flow back to the tank.
SteveC
