This is a desperate Dad trying to help a total despondent son. So bear with me!
Son has an 1980's Nissan with a freshly built (not by him) SR20 turbo engine.
At the weekend he fitted various temp and pressure gauges to protect his new investment (the engine). After a bit of a mishap with the oil temp sensor, we lost about 0.75 litre of oil. But we corrected that problem and re-started the engine all ok. There was still showing about 1/4 above the lower line on the dipstick so figured it would be OK for a gentle run to check for leaks and get fuel and oil.
When he came back, literally in the last few seconds before he switched off, the engine started making like a creaking noise (not a knocking) and stopped. He re-started it again for about 2 seconds, and it ran but with the creaking sound, so he switched off immediately.
We looked in the oil filler cap and it was very hot, and apparently dry.
I also noticed that the oil filter (which has been re-sited away from the engine) was cold. But we know that oil was getting there before because we lost some via the temp sensor hole earlier.
The obvious fear is some sort of oil starvation juding by the pointers mentioned above.
The question is, what could have caused the starvation (would shortage of oil caused it as it was still 1/4 on the stick?) and what likely damage could have happened in that brief period of noise?
I want to try to help him with some reasoned advice once the despair has made way for action.
Any comments gratefully received.
