Thread Tools
Old 19-06-2019   #1
South Africa
Headlights Problem
Hi guys
It's been a while since I posted my car had been fine until last week when I started to experience faulty headlights when I flick on the switch the headlights doesn't come on until after sometime flickering the switch however the indicators and everything is working fine. I removed the steering shroud over the weekend but couldn't find anything wrong put it back on and they were working just fine until they die completely today please help is it a relay or a faulty earth?
tumi1986 is offline Reply With Quote Quote
Old 20-06-2019   #2
South Africa
Re: Headlights Problem
smack the fuse box and see if they come on? This is SOP for when I need to switch on my head lights ... turn on lights with stalk, then smack fuse box. I do have a spare fuse box just need to install it.
dadecoza is offline Reply With Quote Quote
Old 21-06-2019   #3
South Africa
Tried that with no luck.
Old 21-06-2019   #4
Iggy64 has donated!
Iggy64 is an honorary friend of the forum :)
Have a look at the thread just above this one on the same topic. Hopefully you will find some answers in the various posts on that.
Iggy64 is offline Reply With Quote Quote
Old 30-06-2019   #5
South Africa
Today I installed the fuse box mentioned earlier. After installation I was happy to see that my headlights now work, however the happiness was short lived when I noticed that the highbeams now does not work.
So I took the old fuse box inside, took it apart and noticed that the one pin was loose. All the pins are crimped in the pc board not soldered. I measured with a multi-meter and the loose pin was indeed related to the headlights. I then cleaned the crimp and added a blob of solder on top of it. Reinstalled to the old box and now everything works 100%
I will probably now take the other one apart and see if I can do a similar fix and keep it as a spare.
Thread Tools
(T) Headlights problem AdViSoRa Punto Evo 0 21-08-2015 23:24
(T) problem with headlights moon_shadow Stilo 14 07-09-2010 13:04
(T) Problem with headlights. themint Punto (Mk2/2b) 2 09-03-2009 16:36
(T) Problem with my headlights. themint Punto (Mk2/2b) 2 08-03-2009 22:32
(G) problem with Headlights thekiid Bravo / Brava 2 06-09-2005 00:34
