Doblo Hi - Newbie - but blue smoke!
Stolengoat
Hi everyone - Just joined here, but not sure if this is in the right forum, but perhaps someone can redirect it if appropriate....
I have a 2008 Doblo 1.3 multijet diesel... just bought it to replace the previous one I had that I nice man drove into while it was parked... he was 3 times over the limit and wrote it off...
Anyway, I bought the replacement in London from a fairly dodgy dealer at a low price and with a warranty that probably isn't worth anything. Took it for a test drive and everything was fine, but about 10 miles down the road it started blowing blue smoke... this continued on and off until I got back to Somerset. I've had it for a bout a week now and it always starts fine, and the car drives fine, but the smoke appears about 10 minutes into the journey and happens most of the time, although it does sometime disappear.
Took it to my local garage and they didn't really have a clue and suggested that I take it to a Fiat Dealer because they might have come across the same problem. It only has about 50k miles on the clock.
The Fiat dealer looked at it today and they seemed confident that it was down to a blocked EGR valve, so my questions are....
1. Does this seem like a likely diagnosis? They seemed confident that it wasn't the turbo unit.
2. How much do you think it would cost to replace, and is this something that a local general mechanic should be able to handle? The dealer gave me a quote of around £600... but that's based on their £85/hr labour rate and a genuine Fiat part.
Many thanks for reading
Try searching Wikihow
Clean-your-EGR-valve
There are YouTube clips as well.
It may well save you a mint.
Then use a fuel additive like Millers Oils Diesel Power Eco Max.
Put in double strength for a while; this will clear out the injectors and the rest of the system.
My mechanic friend recommended this about 12 years ago and I have used it in my diesel cars ever since. No EGR or injector problems whatsoever.
Go On: Get Your Hands Dirty!...You know you want to!:yuck:
