Hi My name is John and I am new on here, so I hope I have posted in the correct section.
I recently had a fault code saying that my dpf was above the correct threshold. I took it out for a spin and regenerated the dpf. Three weeks later I am at 62% clogging on my DPF according to multiecuscan (registered) and I am driving for about 10 mins then I am now getting a fault saying that My differential sensor has and still reads high and must peform a regeneration immediately.
So I cleared the fault again and it now says normal clogging at 62% so I drove the 10 mins back towards my house when yet again the fault comes back up. still 62 percent clogging but now reads to be regenerated and the same fault code about the differential sensor.
surely if my dpf was clogged and there was a high reading, the fault code would come back on immediatley. am i right or is this not so,
I dont want to force a regeneration if i dont have to, plus if my dpf is reading 62% it can not be blocked,
also is it true that the doblo will not regen itself until its above 80 % any way.
im guessing its a faulty sensor. what do you guys think. seems like this dpf is more trouble than its worth.
would appreciate any help wether obvious or not. cause i may be missing something obvious here.
thanks again and sorry for the mass of message
John
John
