Installed 2.0 turbo engine from the Fiat Coupe. Four-wheel drive on the Lancia delta integrale with viscous coupling and LSD Torshen. The machine is varied and redone almost everything except the body and passenger compartment - all wiring, fuel and brake lines, brake, suspension, exhaust system, fuel tank, redesigned interior, a torpedo, instrument panel, etc. Most of the parts and components are taken from the donor - Fiat coupe, Lancia dedra, Alfa romeo 155q4, 166, Lancia prisma and a number of other machines. In addition, it established a number of tuning components to better realize the potential of the machine.
Spec sheet:
Body - Fiat Bravo, the original body kit Abarth.
Motor - swap on Fiat Coupe 2.0 16 turbo.
Turbine - Tb 0385
Blow-off - HKS ssqv 2
Inlet - K & N panel filter
Intercooler FMIC
3 port solenoid control supercharged MAC
Bustkontroller Blitz Dual SBC Spec S
Turbo timer HKS type 1
Issue - 63mm full float MG-Race + Atiho + Remus wild label.
Protivootlivnaya system with 2 pumps.
Bosch pump 044 and pump Walbro 140 flight hours
Fuel wiring kit
Custom firmware ECU
Spark plugs - NGK Iridium BPR6EIX
Engine start button JDM
Wheel Drive - 4WD - diff gear 43/19 with Ferguson viscous coupling of the Lancia Dedra, rear gear 43/19 Alfa Romeo 155Q4 Torshen 5: 1.
GP - 19/63.
Suspension - Koni, spring Kilen.
Wheels - Fiat Coupe 16 "
Brakes - front disc Brembo 305 mm + 4-piston Brembo calipers on the Alfa Romeo 166 + reinforced hoses Hel, rear disc Brembo calipers 240 mm + Fiat Coupe 20v turbo.
Front seats - leather Fiat Coupe
Rudder - Fiat Coupe
Leather CPR - Fiat Coupe
Steering column switch - Fiat Coupe
Dashboard - Fiat Coupe
Additional sensors - Defi CR Advance - Boost pressure, voltmeter, fuel boost, EGT.
Head Unit - Pioneer.
Two-Front DLS.
Two rear DLS 6/9
Subwoofer Kicx - ICQ300
Amplifiers - PowerAcoustik, Magnat
Interior LED lighting.
More details can be found on this link https://www.drive2.ru/r/fiat/552880/
Spec sheet:
Turbine - Tb 0385
Intercooler FMIC
Fuel wiring kit
Custom firmware ECU
GP - 19/63.
Rudder - Fiat Coupe
Two-Front DLS.
Two rear DLS 6/9
