Technical  Need help naming the parts
Platt
The Hague
Could anyone help me naming some things on the photo?
It's my Marea Weekend ELX 1.6 16v.
I allready put the numbers in for you.
Thanks in advance!
greetz Philip
00-throttle position sensor.
01-idle control valve.
02-inlet temp sensor.
03-vacuum pipe going to?????(where does this go?).
04-vacuum pipe to brake servo.
05-vacuum pipe to purge canister.
Hope this helps.
03-vacuum pipe to fuel pressure regulator
05-vacuum pipe to purge canister/carbon filter+fuel vapour cut-off valve(can be located at in the right wheel arch compartment trim)
