- Apr 8, 2004
- 25,219
- 3,671
Yes the handling on modern fiat hatchbacks is a bit of a joke, completely disconnected feeling.
Shame theres no real figures for handling, something on paper like 0-60 or BHP. .
Grip would be easy to measure. Find big area of tarmac, have cars drive round in constant radius circles at ever increasing speed. First one to fall off looses. You could even do it by remote, to eradicate the possibility of super subtle driver input.
Although you could quantify roadholding by recording g. figures as an example, you can't quantify handling in the same way because it's very subjective. This could be why two F1 drivers in the same team set their otherwise identical cars up differently. This could also be why the much vaunted Stig on Top Gear advises his celebrities to take a different line from the one all the F1 drivers seem to take.Shame theres no real figures for handling, something on paper like 0-60 or BHP.
Although you could quantify roadholding by recording g. figures as an example, you can't quantify handling in the same way because it's very subjective. .
= Gaz37 Handling is how a car "feels" so cannot be measured or quantified as it is entirely subjective.
Grip on the other hand can be measured,
The Delta in question dates from (if memory serves me) around 1980 and first came out in 1.5 litre petrol form. It was based on (either) the Tipo/Tempra (or their own floor pan). A 1.3 was added followed by the 1.5 being replaced by the 1.6 twin cam 8 valve four from FIAT first in carburettor form followed by the HF Turbo model. All the engines later got (i.e.) fuel injection. The 2 litre four with Turbo arrived which put out about 185 bhp and this was followed by a 16 valve model which gave from around 205 bhp to 220 (ish). It was the naturally aspirated and turbo versions of these engines that first went into the Coupe.Strange how the delta beats the bravo, when i thought the delta was a bravo, with a different body shell, and eveything in the engine bay andunderneath was a fiat bravo.
No, because I quoted before I read your post.Is there an echo in here
They were then replaced by the 5 cylinder models. The Delta was probably quicker because of its 4WD system and Torsen centre diff.
Later versions of the Delta with the newer body shell were based on the Bravo but as far as I can remember was never offered with 4WD but used a Torsen diff again to give it reasonable traction.
The current Lancia (Chrysler) Delta is based on a stretched version of the current Bravo (I hope).
Before that they used either flat 4 or V 4 units of their own design and manufacture. I can understand why the flat 4 motors disappeared as they can only really be mounted ahead of the front axle which makes the car nose heavy or behind which would make it too long. In fact I can only remember one car with a front mounted flat 4 that was successful and that was the Alfasud.
The V4 though should have had a lot going for it as it is as short as a flat 4 and could be used longtitudinally or across the body like a front drive V6 such as the Alfa 166. One of the problems a modern V engine has though is duplication. A traditional American V8 for example, many of which haven't really changed in 50 or 60 years have 2 valves per cylinder but only 1 camshaft which sits down in the V. An engine such as the Alfa (Holden) V6 has 24 valves and 4 camshafts so a modern day Lancia V4 would have 4 cams, 2 sets of cambelts and would almost certainly cost quite a lot more to build than an in line motor.
