Old 30-11-2009   #1
seicento speedometer problems
Hi all can any one help me with the speedo it is sticking at 40mph when you 1st start up
many thanks
Dan
danielscott is offline Reply With Quote Quote
Old 30-11-2009   #2
Trader Rating: 5
fingers99 has donated!
Re: seicento speedometer problems
If cable operated, it'd be worthwhile trying a new cable. If digital (MPI cars) suspect the wiring to the speed sensor (on the differential) or the speed sensor itself.
Failing that, the unit is probably fubar, but if cable you might check that no grease has entered the unit. Either should be dirt cheap from a scrappy.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 30-11-2009   #3
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
either way youll have to remove your instrument pod. There is a guide on how to remove this in the Seicento guides
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
(T) Gears, Speedometer and major problems.... appaz88 Punto (Mk2/2b) 3 13-10-2009 13:37
(T) Help please. Speedometer & Rev Counter problems with my Ulysse ratboy125 Ulysse 1 20-08-2009 14:12
(T) '53 plate seicento speedometer susanakazippy Cinquecento / Seicento 9 04-04-2009 00:29
(G) Speedometer and Starter Motor Problems MikeSalt Punto (Mk2/2b) 4 11-07-2008 08:41
(G) Seicento Problems!!!! Lilyellowcargirl Cinquecento / Seicento 1 21-06-2008 13:40
