its a W reg Fiat bravo 1.2 80 16v. Its engine seized about 1yr ago and it was replaced, and as far as i can recall the clutch was done also.
The car will not go into any gear whilst the engine is running and the clutch pedal depressed. It gives a resounding "cant find it - grind it" noise if i try and put it into gear.
When i press the clutch down, about 3/4 pressed down there is like a grinding feel (cant really discribe it) - but it may be related to the hydraulic pump thing I can see under the battery cradle.
There are no warning lights on the dash and the brake fluid level is fine.
the car is now un-driveable, and im looking to see if anyone can shed any light on the possible issues.
I dont drive, posting for the missus, so forgive me for sketchy info.
Personally i think it is the clutch, but im no mechanic. If it is, is this simple enough to replace yourself. I have done the exhaust, shocks, windows, etc in the past, so im not too much of a noob.
any advice would be appreciated.
thanx in advance
thanx in advance
