The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
I have found the radio codes shop, but not sure what make this is... it says Delphi, is that one where it's not possible to find the code ?
Wonder if the white writing is anything to do with it, but not 4 digits...
Sadly it seems so, the code is only readable from the eeprom chip 😞
Could I please get a code for the below Bosch head unit (donated member). Thank you.
Hello Sir, I bought a used radio for my Linea car, but I don't have the code. I would be very grateful if you could help me find it.
I'm listing two serial numbers.
815CM0387E1030843
7 640 387 316
Hi everyone, I'm trying to source a replacement cd/radio with BT for my 2018 Doblo Cargo. For some reason it won't go past the welcome message on the display. I've disconnected the battery for a reset, but still the same. Before I buy a like for like replacement, are codes still available? (For a donation etc). Many thanks in advance for your help or information. Here's a pic from one for sale, which has thr the exact same connections as mine.
Hi everyone, I'm trying to source a replacement cd/radio with BT for my 2018 Doblo Cargo. For some reason it won't go past the welcome message on the display. I've disconnected the battery for a reset, but still the same. Before I buy a like for like replacement, are codes still available? (For a donation etc). Many thanks in advance for your help or information. Here's a pic from one for sale, which has thr the exact same connections as mine. View attachment 475687
What is the model number of that radio? If it's a Delphi one, we can't decode it.
Thanks for your reply. My original one is a Delphi, and I suppose a like for like one would be the same. Unless some older ones were a different make but the same shape?
