The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
I have the Blaupunkt idc a09 5 disc indash changer but lost my code long ago model 7 607 769 150 serial BP 915024335287
Thanks guys!!:worship:
Hi, I would like to get a code for my Fiat 500 radio and place some questions.
I already make a donation.
The serial numbers in my radio are:
BP829090801914
7 678 290 316
034502
The problem that I have is since I have to change the battery. Previously to the change I was getting intermitent problems with radio and control panel. I asket to my local dealer and told me that I should change the battery. I did it and the problems gone out... except the radio ask for the code. I asked to my local dealer and they gave me his code: 2534 that is the same that I have in documentation card but when I tryed to unlock the radio with this code it don't worked! I tryed a few times but each time I have to wait a lot more of time to place the code.
The last time was about 12h. If you give me a new code, what I should do to proceed with the unlock?
Thanks!
PD.: Sorry for my bad english!
BP829090801914
7 678 290 316
034502
Thanks!
Hi, Welcome to the FF.
Thanks for donating to the forum.
You have the correct digits, but in the wrong order.
The code for your serial number is: 2453
Leave the radio and ignition switched on until the display shows " CODE " then " - - - - ", then enter the correct code.
