![]() | #1 | ||
Posts: 204 Thanks: 0 Trader Rating: 0 ![]() | is this ok?? (and safe) putting the amp under the dash near the HU???
![]() | #2 |
![]() | Re: is this ok?? (and safe) As long as its the right way up and the top isn't covered....
__________________ NA8C Eunos Roadster - Epic fun ![]() ![]() ![]() www.puntomk2.co.uk - For all your Punto Mk2/2b/Grande needs.... And some awesome banter ![]() |
![]() | #3 | ||
Posts: 204 Thanks: 0 Trader Rating: 0 ![]() | Re: is this ok?? (and safe) ok, would I have to make any modifications to the fixing brackets?? thanks again
![]() | #4 |
Posts: 6,406 Thanks: 54 Trader Rating: 3 ![]() | Re: is this ok?? (and safe) Yeah mounting it upside down would mean that it would overheat as the heat given off would just rise up back into the amp, which isn't good. And you need a few inches of air space around the amp to allow cooling unless you added forced cooling, i.e. fans. |
![]() | #5 |
![]() | Re: is this ok?? (and safe) Not sure, what car have you got? where are you thinking of putting the amp (Photoshop a circle on a picture of the dash so I know where you're thinking of putting it)?
![]() | #6 | ||
| Re: is this ok?? (and safe) It will be fine under the dash as long as you leave it some room to passively cool (although a good idea to add a fan to give some airflow). As for mounts, you will need to make up some form of shelf/brackets for it to be secured properly. Other considerations though: - Make sure you mount it well away from other power sources otherwise you'll end up with alternator whine. - Make sure you mount it well away from the hot air ducts from the dash as it will cook your amp. - If your amp is only a passive cooled one, id add lots of fans as there is no airflow under the dash out the way.
![]() | #7 | ||
Posts: 204 Thanks: 0 Trader Rating: 0 ![]() | Re: is this ok?? (and safe) yeah, its a sei
![]() | #8 |
![]() | ![]() I would definately think about forced cooling, as amps can get pretty hot, and so can your dash in the summer months with the sun blazing on it. Otherwise, your pretty safe, just make sure it doesn't interfeare with other things under the dash ![]()
__________________ No Longer a Doblo Owner ![]() |
![]() | #9 |
![]() | Re: is this ok?? (and safe) Can't you just put it under the seat? ![]()
![]() | #10 |
Posts: 6,406 Thanks: 54 Trader Rating: 3 ![]() | Re: is this ok?? (and safe) ![]() Can't you just put it under the seat? ![]() ![]() And don't say there's no room ![]() |
![]() | #11 |
![]() | Re: is this ok?? (and safe) Well I was under the assumption that he was using it for the front speakers Chaos ![]() ![]()
![]() | #12 |
Posts: 6,406 Thanks: 54 Trader Rating: 3 ![]() | Re: is this ok?? (and safe) ![]() Well I was under the assumption that he was using it for the front speakers Chaos ![]() ![]() ![]() ![]() |
![]() | #13 |
![]() | Re: is this ok?? (and safe) Suppose so, in a cinq its only a couple of feet difference ![]()
![]() | #14 | ||
Posts: 204 Thanks: 0 Trader Rating: 0 ![]() | Re: is this ok?? (and safe) no, I just want it there so I can tweek it to get the right sound. easy to get to. if you know what I mean?
![]() | #15 |
Posts: 6,406 Thanks: 54 Trader Rating: 3 ![]() | Re: is this ok?? (and safe) ![]() no, I just want it there so I can tweek it to get the right sound. easy to get to. if you know what I mean? ![]() |
