FIAT Auto Specialist Team
Thread Tools
Old 29-08-2005   #1
Mounting an amp and sub........
I've recently bought this off ebay........
Its a 12" 1000w sub and amp just wondering i'd be ok wiring it ion but how about actually mounting it in my mk1 punto boot? will i have to drill?
badboy is offline Reply With Quote Quote
Old 29-08-2005   #2
Ah. Not good...
chaos's Avatar
Trader Rating: 3
chaos has donated!
League Bowling Champion, Bikini Bounce Champion, Bowling tgfg Champion, Island Bowling Champion, Lawinen Surfer Champion, Missing Link Champion
Re: Mounting an amp and sub........
It may be best to make up a false floor and bolt it to that.
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline Reply With Quote Quote
Old 30-08-2005   #3
all over your face
CinquePunto's Avatar
CinquePunto has donated!
The first thing to do is remove the boot carpet and draw round it onto some (18mm) mdf and cut out to make a false floor.
Bolt that down to the boot floor, making sure there are no brake lines in the way underneath the car (I dont think there are) I used screws to do this, purely so I could undo them if I had a puncture, and cover the mdf with the carpet
Then use some corner braces, you can get these in Homebase/ B&Q for a couple of quid, then screw them to both the sub and the false floor, it is best probably to use at least 4 for this task, using woodscrews, but make sure the screws are shorter than the thickness of the false floor, or you'll puncture the spare.
If done properly, this will not only stop the sub moving around, but will also improve the bass response of the sub, as it wont move the box, just the air.
If you find this post helpful, do not forget to "report this post to a moderator" for reputation
CinquePunto - Five Point Photography - Adam
CinquePunto is offline Reply With Quote Quote
Old 30-08-2005   #4
Ah. Not good...
chaos's Avatar
Trader Rating: 3
chaos has donated!
Quote Originally Posted by cinqysxmk2
Blatant plug there
Old 30-08-2005   #5
all over your face
Yeah, but most people seem to ferget if they actually do find it useful...
Old 30-08-2005   #6
Ah. Not good...
chaos's Avatar
Trader Rating: 3
chaos has donated!
True.
Old 30-08-2005   #7
Whoa thats a lot to take in for a novice Thanx for the guide i'll try it out.........
I'm wondering any other way than drilling in my car?? or anywhere i can go in the birmingham region to get it done professionally?
Old 30-08-2005   #8
Ive got a false floor you can have for 15 mate, PM me for details, Fits that AMp and sub Perfectly
GhettoMoose is offline Reply With Quote Quote
Old 31-08-2005   #9
all over your face
If the false floor is tight enough fitting, you could most likely push in some wedges around the sides which will hold it tightly, but this isn't quite as good as screws...
You'll probably have to drill a hole somewhere in the boot for the earth wire anyway...
Old 12-09-2005   #10
just want to say a massive thanx to everyone who helped me out.... just finished installing my amp and sub in my car now,(FINALLY!!!) its functional but now i'm going to mount it as recommended in this topic!
Old 13-09-2005   #11
all over your face
do u have pics?
Old 13-09-2005   #12
dont really need to mount to the floor but up to u in my clio the floor is laid in as it is on the punto and the boxes just sit on top of it
phil_GT is offline Reply With Quote Quote
Old 13-09-2005   #13
Ah. Not good...
chaos's Avatar
Trader Rating: 3
chaos has donated!
Quote Originally Posted by phil_GT
Don't they slide around when cornering?
Old 13-09-2005   #14
no u felt the weight of a sub box with a amp in lol i have 2 side by side and they dont move n e where
Old 13-09-2005   #15
paulbfd has donated!
Never under estimate the power of a sub box that's not fixed down in a crash.
Black Panda 100HP
Alpine CDA-7944 headunit / Audison Bit One processor.
Audison LRX5.1 / Hertz MLK2 & Audison TH Basso.
Chord Epic speaker cable & Anthem 2 RCA leads.
paulbfd is offline Reply With Quote Quote
Thread Tools
