almcluskey
No longer have the manual for the original headunit, so was wondering if someone could point me in the right direction on the colour codes. I've had a look and the colouring at the moment is:
Pin
1 Pink/Black
2 Empty
3 Pink/White
4 Red (12V+?)
5 Violet
6 Empty
7 Empty
8 Black (Ground?)
I take it that Red is 12V+ and black is ground. Beyond that what are the colours?
I've just bought a JVC head unit, which is powered when I plug it into the current ISO connector, as I can open the motorised face and the display will come on when I press the display button. However, the unit will not fully power on when I press the power switch (in fact the light on the power switch goes out after a couple of seconds of being plugged in) and will not come on if I try to select a source. I figure that I need to move the red on the original ISO connector to pin 7, but do I need to move anything to pin 4?
There's an ISO connector with the unit, and the important cables are as follows:
Pin
1 Empty
2 Brown
3 Empty
4 Yellow (12V Memory Backup)
5 Blue/White
6 Orange/White
7 Red (12V+)
8 Black (Ground)
Anyone any idea what colours correspond and which pins they need to go in? Presumably I'll need to move the red wire on the original ISO to the 7 pin, but which do I need to move to the 4 pin? Help much appreciated.
Pin
1 Pink/Black
2 Empty
3 Pink/White
4 Red (12V+?)
5 Violet
6 Empty
7 Empty
8 Black (Ground?)
Pin
1 Empty
2 Brown
3 Empty
5 Blue/White
6 Orange/White
7 Red (12V+)
8 Black (Ground)
