![]() | #1 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | Swapping factory stereo... Hi, this is my first time on the Fiat forum and i'm looking for a little help changing the standard tape player in my 2002 stilo for an mp3 goodmans (which i have already bought). The problem i'm having is once the factory stereo is out and the new one is plugged in i'm getting no power?!?! I'm new to adapting my car in anyway and assumed with the adaptor it would be plug and play but to no avail...anyone got an idea?
![]() | #2 | ||
![]() | Re: Swapping factory stereo... Hi, this is my first time on the Fiat forum and i'm looking for a little help changing the standard tape player in my 2002 stilo for an mp3 goodmans (which i have already bought). The problem i'm having is once the factory stereo is out and the new one is plugged in i'm getting no power?!?! I'm new to adapting my car in anyway and assumed with the adaptor it would be plug and play but to no avail...anyone got an idea?
![]() | #3 |
Posts: 292 Thanks: 16 Trader Rating: 0 ![]() | Re: Swapping factory stereo... theres a guide in the guide section :-) (look at the top of the page, on the blue menu bar, second across is the guide tab)
__________________ 05 Stilo 1.9 JTD 115 3 Door |
![]() | #4 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | Re: Swapping factory stereo... Thank you both for the advice, the guide really helped, however i re-wired the ISO but went to install the radio and still got no power...I looked at the cable from the car and all i have are red, black and thin two pink cables...no additional power cable that would feed onto the rewired ISO. Does anyone know where i have gone wrong or am i unable to fit a new stereo? ![]()
![]() | #5 | ||
Posts: 489 Thanks: 12 Trader Rating: 0 ![]() | Re: Swapping factory stereo... You will be able to fit a stereo! Don't worry. There should be either 1 cable that is always live & 1 thats only live with the ignition on OR just one permanat live. You'll need a test lamp or volt meter to check this. You also check that the earth [negative] is good by doing this. If you don't get voltage try checking for voltage from the battery negative post to your radio wires to eliminate a fault with the earth wire. Good luck ! ![]()
![]() | #6 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | Re: Swapping factory stereo... I do have just a live cable, although doesnt seem to give enough power...i think i might have to take it to a professional, does anyone know of anyone? dare i say halfords ![]()
![]() | #7 |
Posts: 11,448 Thanks: 401 Trader Rating: 0 ![]() | Re: Swapping factory stereo... do all of the wires line up? Can you get some pics up so we can see what you have done.
__________________ Car Audio Goodness at its best for sale. http://www.fiatforum.com/classifieds...?product=28141 |
![]() | Medds | Punto (Mk2/2b) | 3 | 25-11-2010 10:49 |
![]() | Pic | Bravo | 1 | 14-03-2008 07:40 |
![]() | Stickman | Cinquecento / Seicento | 1 | 19-11-2007 18:27 |
![]() | Kieran83 | Stilo | 0 | 08-05-2006 00:29 |
![]() | gavoleary | Stilo | 3 | 03-02-2006 21:30 |
