Poor Reception On The Radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
This wont help you ... but i posted something similar to this before and had nobody reply to it!... mines a punto mk2 ... strange.. it wont even pick up Kiss 100 and im in Essex?
Have you thought about only listening to the radio when you are on the top of a hill?
This should easily fix the problem.
Or just make sure the aerial connections are clean and snug into the radio, from the tip of the aerial, to the radio itself.
Kiss 100 is got to be the hardest stattion to have good signal on, its on on one wavelength so if theres any interferance your bummed
check connection where arial screws into mounting point, on roof i pressume als check its properly plugged into the rear of HU
Dont you have a tiny little two incher of a aerial?
Id try cleaning all the contacts and then an original aerial then another radio.
No mate. I have a sporting aerial back on now for that oem look. The radio is a near new alpine £130 HU so I don't think it could be that either. Possibly the connection on the roof? Does this come off easily? as in from the inside
