MattBailey
- Aug 3, 2009
- 13
- 2
Hi Everyone,
I know a question like this gets asked every day, and I have used the search function to try and find some guidance, but all the wiring on these Fiats seems to be different, and I don't want to get it wrong...!
Basically - I am trying to wire up an Alpine CDE-9871R in my 2004 Mk2B Punto 1.2 8V Active. But the wires don't match up - this is what I have on both the car and the HU ISO adapter pins:
Car:
Pin 1: Pink/Black
Pin 2: Empty
Pin 3: Blue/Pink
Pin 4: Red/White
Pin 5: Grey
Pin 6: Empty
Pin 7: Empty
Pin 8: Black (Ground)
Head unit:
Pin 1: Empty
Pin 2: Empty
Pin 3: Empty
Pin 4: Yellow
Pin 5: Blue
Pin 6: Empty
Pin 7: Red
So, I did as was suggested on the other threads on the forums, I bodged it a bit (used tape!) so that the live from the car goes into both the yellow and red wires from the HU. So the stereo works! Good times.
But I am worried that it is draining the battery when it is off. I haven't fitted it yet, but if I do, the fascia will come off and the iPod will be disconnected every time the car is stopped. But I have read lots of stories about people's batteries going flat because of the HU draining them, and we don't have a second car or anything to jump the car with if that happens - potentially embarassing...
So, is there a way I can get it to turn on and off with the ignition? I don't know if there is a switched pin - where would it be and how would I test for it? I'm not really savvy enough to run anything from the steering column or cigarette lighter, not without step by step instructions.
So is there a solution to stop it draining the battery? Or will it really matter considering I will disconnect the fascia and iPod every time the car is off?
Any opinions or information would be welcome!
Cheers,
Matt
Car:
Pin 1: Pink/Black
Pin 2: Empty
Pin 3: Blue/Pink
Pin 4: Red/White
Pin 5: Grey
Pin 6: Empty
Pin 7: Empty
Head unit:
Pin 1: Empty
Pin 2: Empty
Pin 3: Empty
Pin 4: Yellow
Pin 5: Blue
Pin 6: Empty
Pin 7: Red
Cheers,
Matt
