Replacing bulbs
So you've got a blown bulb, the fronts are doable without removing the cluster
But some are tight!, if you struggle consult an expert like halfords (but pay way to much for bulb and fitting), your local mechanic, or a friend who's got small hands!
The rears, is easy
In the spare boot kit you should have this
No tools in boot? No problem a 17mm socket and posi screwdriver is all it is!
Locate the 2 stud fixings Top and bottom
Using the spare boot tools - work the nuts free like so
2 nuts removed pull the cluster carefully away from the car, to expose your connection
Then using the screwdriver - remove the 4 screws on the back
3 are located around the connection seal
1 is located just below the top stud
Pull back off - twist and pull defective bulb out
Refit new bulb - push and twist
Refit back cover - refit screws - refit connection - reseat lights - Fit nuts finger tight - tighten with tool - Test!
**REMEMBER THE REAR SIDELIGHTS ARE 10W NOT 5W!**
