Re-assembly!
Re assemble your hub, copper slipping where you should as you go.
Route the cable under the car using the clips as you go and making sure all the parts of the outer are in the right places.
poke the cable end through the hole to the interior of your car (you should see the light).
lean into your car and pull the cable end inboard as much as possible, then go check your inspection hole in the back of the hub to satisfy yourself its all still connected properly.
As you pull the cable in board the cable outer will start to poke through (remember the grommit bit you poked out earlier) this can be pulled into position so your cable outer is correct.
Replace the inspection cover rubber on the hub back plate, put your wheel back on and drop your car!
