What I did was took the mirror off, then found the thinnest screwdriver possible, removed the inner trim, look near the mirror from the inside the car you can see the underside of the trim piece, get your get thin screwdriver and place it in the lip where it grips, prise it away and use another screwdriver to push up and once you have the first couple of inchs off the rest will come off by hand.........................................
  • Like
Reactions: maxinou
